Learn about the camera’s accessibility functions (user assistance functions)
See below for information on various operation procedures. Also refer to the camera’s Help Guide.
Screen Reader
Only some languages may be supported for this function depending on the model. This function is available only when the language set in the menu is supported by this function.
How to enable the screen reader function
Select
How to set the speed when reading aloud
Select
How to set the volume when reading aloud
Select
Focus Magnifier
How to enable the focus magnifier function
- Select
(Focus) → Focus Assistant → Focus Magnifier
- Press the center of the control wheel to enlarge the image and select the area you want to enlarge using top/bottom/left/right side of the control wheel.
How to use the focus magnifier function by touch operation (When shooting in manual focus mode)
When Touch Func. in Shooting is set to Touch Focus, you can magnify the image and adjust the focus by touching the monitor.
When the focus mode is Manual Focus, you can perform Focus Magnifier by double-tapping the area to focus on while shooting with the monitor.
While shooting with the viewfinder, a frame is displayed in the center of the monitor by double-tapping and you can move the frame by dragging it. The image is magnified by pressing the center of the control wheel.
On the MENU screen, configure the following settings:
- Select
(Setup) → Touch Operation → Touch Operation → On
- Select
(Setup) → Touch Operation → Touch Panel/Pad → Set properly for your use.
- Select
(Setup) → Touch Operation → Touch Panel Settings → Shooting Screen → Shooting Screen → On
- Select
(Setup) → Touch Operation → Touch Panel Settings → Shooting Screen → Touch Func. in Shooting → Touch Focus
- Select
(Setup) → Touch Operation → Touch Pad Settings → Set properly for your use.
Focus Map (Movie)
How to enable the focus map function
Select
Peaking Display
How to enable the peaking function
Select
How to set the level of enhancement of in-focus areas
Select
How to set the color used to enhance in-focus areas
Select
Subject Recognition in AF
How to enable the subject recognition in AF function
- Select
(Focus) → Subject Recognition →
Subject Recog in AF → On
- Select
Recognition Target → Select a subject.
Touch Tracking
How to use the touch tracking function
- Select
- Select
- Select
- Select
(Setup) → Touch Operation → Touch Panel Settings → Shooting Screen → Touch Func. in Shooting → Touch Tracking
- Select
Touch Focus
You can also touch a subject to focus on it when shooting movies. (When shooting with the monitor)
How to enable the touch focus function
- Select
- Select
- Select
- Select
- Select
Note: This function is available when Focus Area is set to Wide, Zone, Center Fix, Tracking: Wide, Tracking: Zone, or Tracking: Center Fix.
Touch Shutter
How to enable the touch shutter function
- Select
- Select
(Setup) → Touch Operation → Touch Panel/Pad → Both Valid or Touch Panel Only
- Select
- Select
(Setup) → Touch Operation → Touch Panel Settings → Shooting Screen → Touch Func. in Shooting → Touch Shutter
Touch AE
You can fine-tune the brightness by sliding the brightness adjustment bar that appears after touching. (When shooting with the monitor)
How to enable the touch AE function
- Select
- Select
- Select
- Select
(Setup) → Touch Operation → Touch Panel Settings → Shooting Screen → Touch Func. in Shooting → Touch AE
- Select
Vari-angle LCD screen
Custom function
How to enable the custom function
To assign a function to a button or dial, select
Aby obejrzeć ten film, trzeba zaakceptować pliki cookie serwisu YouTube
Wejdź do ustawień plików cookie poniżej, przejdź do sekcji „Funkcjonalne” i włącz pliki cookie serwisu YouTube.
Powiązane artykuły
Zarejestruj swój produkt
Zapewnij sobie dostęp do wszystkich informacji, aktualizacji produktu oraz atrakcyjnych ofert
Społeczność Sony
Odwiedź portal naszej Społeczności i dziel się swoimi doświadczeniami i rozwiązaniami z innymi klientami Sony
Kontakt z zespołem pomocy technicznej
Skontaktuj się z zespołem pomocy technicznej firmy Sony
Gwarancja, naprawy i części zamienne
Zamów naprawę produktu, kontroluj jej przebieg i poznaj rozwiązania pozwalające uniknąć niektórych napraw
