Identyfikator artykułu : 00253082 / Ostatnia modyfikacja : 30.08.2021Drukowanie
What is the resolution when shooting in Super Slow Motion?
    Resolution and angle-of-view change as follows, depending on the selected frame rate.
    - 120fps or 240fps setting
      You can record at 1920 x 1080 Full HD resolution,
    - 480fps setting
      You can record at 720 x 480 equivalent image quality (SD resolution).
    - 960fps setting
      You can record at 360 x 240 equivalent image quality, and the angle-of-view shifts 2 times toward the telephoto side.
