Identyfikator artykułu : 00125067 / Ostatnia modyfikacja : 25.05.2022Drukowanie
Does the unit support the use of a USB hub? (Copy of Answer 125066)
Polish
    The use of USB hubs is not supported for your Sony product.
    Do not connect other devices via a USB hub. Doing so may interrupt the unit, preventing it from working properly.
